converting .stp file to 3d pdf
  • Thread starter Thread starter prozium
  • Start date Start date
P
prozium
Guest
i want to convert my two .stp files to 3d pdf format but unable to do so upto now after using so many softwares. Anybody having required software to convert it...pleasereply me at sah.prateek@mahindra.com....urgent requirement...help will be appreciated
Are you saying that you cannot do this from pro engineer?
i am just unable to do it. whether due to my pathetic pc or watsoever the problem is
send the files
Hi
I think you want to make a cad drawing. If so open the part file go to File menu---New---Drawing---then add the required dimensions. after this click file---save a copy and choose .pdf form. And if you wish to put a 3d view as well you can insert a general view.
Edited by: faisalmk
