convert word in pdf 1
wati
Chemical
NL
please help me to convert word and excel documents in pdf documents ..step by step
any help will be appreciated
Buy or download the software.
Search Google for pdf writer or pdf creator.
An even better option is to download OpenOffice from OpenOffice.org - thoes open source applications read and write WOrd and Excel documents and include pfd export. In fact, you can use OpenOffic einstead of Excel and Word.
Download free software from pdf995.com
It will create a print driver on your system that you can use to "print" pdf's in word and excel. Instead of actually printing, it creates a pdf.
If you already have Acrobat then the process is simple. Select file in the toolbar then create from file pdf or create from multiple files into pdf. Another way is by opening either word or excel file. You will notice a Acrobat symbols in the upper right of your screen. Select convert to pdf and follow the instructions. Hope this helps.
John
Thanks everyone for your advice.I will try what cadstudent suggests, think this is the most simple way.
thanks..
wati
