Convert Solidworks 2004 model to 2000i
brivera
I have a Solidworks 2004 model I need converted to 2000i in order to open it. Can someone please convert these for me?
Do you mean convert SWx 2004 to SWx 2000? If so can't be done.....SWx is not backwards compatible. Or do you me Pro/E 2000i? if so you will have to convert the SWx 2004 file to either a STeP or IGES but then you will have no feature history.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
Good catch Heckler. I didn't think of Pro/E.
Chris
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 10-27-06)
ACAD 2000i? Not sure how to do it. You can save it as an acis (.acis) file, but if you use the "acisin" command in ACAD, you get the following error: "Save file is from a later version of Acis".
SW07 SP1.0
Flores
smcadman,
When you save the file out of SW as an ACIS file, click on the options button in the save as dialog box. This allows you to specify the ACIS version for the translation.
Timelord
Then there's the answer: save as acis version 1.6 (assuming he means ACAD 2000i)
SW07 SP1.0
Flores
It sounds to me like he has a few SW files and a seat of AutoCAD 2000i. If that is the case, 2000i is a 2D program and unless he has MDT5 as well translating the part files won't help. If the SW files are .drw What about having the source of the files do a save-as .dwg?
Harold
SW2007 SP1.0 OW2006 SP4.0
ACAD is not a 2D program, it's 3D. Many users just never learn how to use 3D. ACAD 2000i has Photo Real and Photo Raytrace rendering, and can rival Photoworks in quality. The setup isn't as easy though.
SW07 SP1.0
Flores
If it is ACAD 200i, he can save from SolidWorks drawing file as DWG, select options, change to older version of ACAD.
Chris
AutoCAD 06
"I have a Solidworks 2004 model I need converted to 2000i"
You can't convert part and assembly models to .dwg, only drawing files.
SW07 SP1.0
Flores
Not to get off the subject but my 2000i opens as a 2D program unless I open it using MDT5 Powerpack. I can't say I miss using MDT/AutoCAD.
It would be helpful to have some clarification from brivera as to what he has and what he wants.
Harold
errr guys ... I think you will find that the OP is asking for someone to do the conversion for him. He has the SW04 model file but presumably not SW. He just needs it converted to a "???? 2000i" compatible format.
brivera ... see faq559-1177 for details of how to upload a file and list what 3D formats the "???? 2000i" can open/import.
[cheers]
I can't do it for him, only guide him. (job sensitivity).
Hopefully somewhere can.
Chris
AutoCAD 06
CBL, gotcha. I thought he didn't know how to convert it.
lumenharold, here is a screenshot of ACAD 2000i.
You will notice all of the 3D buttons, such as Solids, Solids Editing, Surfaces, Shading, Rendering, etc. You just have to turn them on. I have MDT6 with Power Pack and it uses ACAD 2002. I do not recall which version of ACAD MDT5 uses.
SW07 SP1.0
Flores
I have MDT5 with power pack and it uses ACAD 2000i
Dennis
SolidWorks 2007 SP1.0
Windows XP Pro, Pentium4 3.00GHz
1.5 GB RAM, Matrox P650
Logitech Marble Mouse, CadMan
