-convert command ?
TheKKK
GR
on intel fortran i compile giving the command:
ifort -convert big_endian myfile.f
What is the "convert" command in gfortran or in lahey compilers?
The above didnt work.
Did you try reading the manual?
TTFN
FAQ731-376
Specifies the format of unformatted files containing numeric data. Type
Code:
ifort /? > ifort.txt
Then have a look at ifort.txt for all the options available.
