Convert an extruded cut to an extruded boss/base
CU001
Hi, I have an intricate cut that I intend to convert to an extruded boss/base. Is there a way to do this in SW2011?
Thanks.
Do you mean creating a form tool from the cut? What's your intent?
SW Premium 2011
64 bit SP4.0
Intel Xenon X5650 @2.67GHz
2.66 GHz 11.9 GB of RAM
TheTick is correct, reuse the sketch, or create a new sketch and use convert entities if that works for you.
You can save the sketch out as a block and use it in another position or save it in the design library etc.
