Convert a Surface Part to Solid
Insert --> Boss/Base --> Thicken", select surface. if surface is an enclosed volume (no gaps), then you can select an option to create volume from closed surface.
Have you knitted the surfaces together?
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
I tried to download the file. No dice. For some reason, Mooload never works for me.
I can't download either. Can you repost to Putfile or similar?
When Mooload first started up it was great, but over the last few months it seems to be down as much as it is up. Probably suffering from too rapid a rise in popularity.
It is working for some people as the posted number of downloads has increased.
[cheers]
Thanks for all the help. I did as was suggested by making sure all surfaces were knitted togrether. Apparently they were NOT. I was then able to make it solid.
Thanks Again
A side question. How do I change Mining to Mechanical??
"How do I change Mining to Mechanical??"
I don't know. Try sending a request to Management at Eng-Tips Forums in the Contacts tab at top right side of this page.
[cheers]
