Is there anything that would prevent me from constructing a ducted enclosure for a window unit, such that I could operate it inside the cooled space like a portable A/C?
BACKGROUND
I live in Jackson, Mississippi and have a workshop in an attached garage that I need to cool. The subdivision’s homeowners association prohibits the conventional installation of a window unit. I have considered portable units, but their cooling capacity will not be able to handle the heat load. Therefore, I am considering purchasing a larger window unit and building an enclosure that will allow me to operate it inside the shop without it being visible from the outside. The enclosure would be designed to draw in outside condenser cooling air and exhaust it outside, similar to the design of the portables. I would use an in-duct fan to overcome the losses due to the duct work and enclosure (the unit's condenser fan would remain functional).
BACKGROUND
