Conversion of Pro/E dimensions to Excel or ASCII file
  • Thread starter Thread starter skraba
  • Start date Start date
S
skraba
Guest
Hello!
Is it possible in some way to convert model dimensions to Excel or ASCII file?
I would like to retrieve model dimensions and put them into Excel file or retrieve them from ASCII file and use them later in calculations.
Best regards,
Jurij Skraba
You can use a Behavioral Modeling Excel analysis and map dimensions to cells in an excel table. Any time you run the analysis, it will pass the values to Excel.
