Convergence and P-Pass????
  • Thread starter Thread starter kiddbd
  • Start date Start date
K
kiddbd
Guest
New to Mechanica. Can anyone give me an explanation and/or and example of whatconvergence and p-passmean in Mechanica? And what does it mean if I set the convergence % to 5%? Thanks for any help.
Dear kiddbd
We are Mechanica consultancy & training specialists in the UK, and we have an explanation of how Mechanica works on our website. To directly to that page, click on http://www.elite-consulting.com/structure2.htm
Kiddbd
I'ts good that you ask first before you make some mechanica analysis.
In mechanica, it uses "p-element" approach in which p stands for polynomial. In old days, FEA uses the "h-element" approach which is similar to our finding an area of an irregular shaped element using integration and derivatives during our school days. in h-element approach, the irreg shape is sliced into elements, called "h" element, the more "h" the higher the accuracy of the analysis but as the number of "h" element rises, the time to analyse versus accuracy becomes impractical.
in mechanica, instead of slicing the irreg shape into increasing elements, it preserves the number of element and just raise the order of the ploynomial up to 10.you can see this in multi-pass convergence method. a 25%convergence means that pass 1 should only have25% difference in accuracy after pass 2 and so on until it reached your assigned polynomial limit.the lower the convergence the higher the accuracy but it will also yield longer computational time. max convergence in mechanica is 25%.
you should read first articles about how mechanica analyzes before you trust him.
