Convection Heat Transfer
Fairy
8
For the purpose of convection Boundary condition, is it necessary to define the convection coefficient? I only have a time based value, but for some reason the program would not let me define a table of the convection coefficient.
Could anyone help
What software are you using? And yes you will need to calculate the h.
Tobalcane
"If you avoid failure, you also avoid success."
I am using Ansys version 11.
It is not simple to find one single value for h. I am modelling a real test and have about 8000 values (over time) for the surface temperature!
Oh ok, I have never used Ansys, I typicaly use Flotherm for this application. for the surface temp, can you avarage it out or is there a huge delta between them? It is sounding more like a transient probem than steady state.
Tobalcane
I suggest that you RF this posting and re-post in the ANSYS forum.
Nonetheless, if your analysis program does the FEA, then the effective htc should flow out of the analysis.
TTFN
FAQ731-376
