vonsteimel
Greetings,
I'm looking for your opinions on the best way to control and/or call out something.
I have someone wanting to install a NPT threaded valve into a tank via a welded boss (see sketch.jpg). Ive been able to get a drawing to work for us here at the shop which was good for a dozen or so test units (see Valve.jpg) But Now the design is ready to go out to the Subcontractors for bidding but I'm questioning how to go about controlling/calling-out both the valve height and the outlet position on the tank. If the boss is at the correct length and the valve is at the correct height then the NPT thread depth will not be to spec, therefore NPT thread go/no-go gauges won't work.
I can get some leeway just by how much PTFE tape is applied to the thread in order to get it to be oriented in the right direction but not enough to leave placement to chance. The valves have to be removed before welding because the float/plunger is plastic and will melt.
I was thinking I'll probably send the contractor a valve to use a gauge or other manufacturer a gauge ourselves and send it out.
Any suggestions?
Thanks,
VS
Any suggestions?
Thanks,
VS
