For the Chemical dosing packages where mostly controlled volume (diaphragm type) pumps are used, for the capacity control, the stroke of the pump is varied either by manual or automatic ( motorised actuator) . Client prefers to have VFD for the capacity control as they have experienced problems in the stroke control methods said above. Whether the above proposal for providing VFD for capacity control for a PD pump is efficient than the stroke control? Thanks to clarify.
