A HAZOP I am currently participating in came upon the following situation: A fired furnace has three sets of burners. Two of the three sets are fed by a common header protected by a single double-block-and-bleed trip valve trio. These two burner sets have their own temperature or pressure control valves downstream of the trips. The third set of burners is on a separate fuel gas header. This line has an upstream block and bleed, which are dedicated trip valves. The downstream (burner side) trip valve, however, is also used as a fail-closed temperature control valve. The question arose as to whether such a "dual use" of the temperature valve is outlawed by FM or any other code. The team did not have resources conveniently available to research this question, and I wondered if any of you generous forum-goers might have an answer. Thanks in advance..
