control valves and piping hydrotest 1
elylrc
20
In the past we have hydrotested systems prior to installing control valves by installing a short spool in lieu of the valve. I have a contractor who is insisting that this is unnecessary. The system is ANSI 600#, Class Location 3, per B31.8 2007. The design pressure is 1440 (not 1480)and the test prtessure is 2016. The valve is by Mokveld.
Any advice will be appreciated.
elylrc,
Methinks you may be undertaking some wishful thinking.
A quick review of ansi b16.34 , par 2.5.3 "Pressure test limitations", 2.5.3.1 "valve in the closed position", and 2.5.3.2 "valve in the open position" makes it explicit, that any pressure test that occurs at a pressure above its 38 C ( 100 F) pressure rating or differential pressure rating is soley at the risk of the user. So that is , zero overpressure is permitted , based on 100 F rating. So, it may be an issue for valves that noomrally operate at 100 F.
It is true that B31 allows 10% overpressure during transients, but if a valve were to fail durig hydrotest, and you were to try to get a free replacement from the vendor, it is likely that he will take refuge in the B16.34 statements.
Pipeline valves are per API 6D per B31.8. I'm sure you may be correct in other applications.
