KnowSeeker
Petroleum
Dear all,
Could anyone help with my query. I work in a refinery and we have some old documents on leakage rates of isolation valves (ball valves). The data sheets specifies design shut off class/leakage rates (Rate A, Rate B through to G) in mm3/s (cubic millimetres per second) as per BS 6755 part 1. However manufacturers and Site have now adopt the ANSI/FCI 70-2 standard that defines 6 shut off classes (Class I through Class VI) in ml/m (milli-litres per minutes).
Does anybody know any documentation that cross references the two standards and any methodology for calculating the leakage rate in ml/m from mm3/s for control valve. I could have used my basic school volume calculation but this is ineluctable given the irregular dimension of the shut off valve. Also which dimension would the calculation take in, the orifice port where the ball/plug seats or flange/pipe size. Many thanks in advance.
