What is the maximum spacing of control joints in 125 mm thick slab-on-grade open air parking garage in Ottawa Ontario Canada climate. I feel that 36 times the slab thickness for a 125 slab = 4500 mm (15 feet) is too far for a salb subject to external environmental temperature changes. I realize that the actual spacing will generally be governed by the column spacing, but what would be the "maximum" permissible spacing to avoid excessive cracking?
