Hi all,
Please I need help for a little issue.
I have a latching relay in a lighting panel board that should control a lighting circuit. This lighting circuit should be controlled from a push button installed in the site and from BMS. The control circuit should take into consideration an override (priority) for the signal coming from the BMS.
Example: If the circuit lighting was turned on from the BMS command, a person on the site doesn't have the right to turn off the circuit, that means if he pushes the push button, the lighting will not turn off. It remains on.
Please can I anyone help me in the control diagram ?
I have made this little proposal, but I think it needs some modifications.
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1432307868/tips/Latching_relay_LUNC_detail_cwip9f.pdf[/url]
Thank you in advance,
Kind Regards,
Rami
Kind Regards,
Rami
