contour drawing for plasmacutting
Walterke
Industrial
Jun 22, 2011
451
We want to make a 30mm thick steel part by plasma-cutting the contour, and then adding small holes etc. on a mill.
I'm having trouble finding a proper way to create both the drawings (drawing for "raw" part and detailed drawing for the mill) and somehow make them dependent on each other and on 1 part number.
Any hints?
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
If you model the part with all the feature, but make sure the hole etc, are at the end of the part history, when you go into drafting (master model concept) enter modelling with in the drawing and wave link the body at time stamp using the last feature beore the whole as the time stamp. Then create a flat pattern of from the WAVE linked body that will give you the cutting profile. You can then add the flat pattern view in the drafting along with normal views of the finished component.
Hope this helps
Cheers
Si.
Best regards
Simon NX7.5.4.4 MP8 - TC 8
Could you add some more info as to how to do this?
What Licenses do I need?
Alternatively: when I add the part in an empty assembly and make an assembly cut in it, I can model it as if I was in the part itself.
Is there a way to do this without having to use the assembly cut? That way I could add a raw material version as a part inside the requested part and model it to the finished part in the main assembly.
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
You need a sheet metal licence for the flat pattern I'm not sure about the WAVE as there are two levels to it. You can use something called a promotion instead of WAVE. Have a look for it in the help notes.
Cheers
Si
Best regards
