ajk1
- Apr 22, 2011
- 1,791
I am checking a 2-span 3-ply built-up wood beam in a newly constructed cottage. It is advantageous to take account of the continuity because one span is significantly less heavily loaded than the other span. It is over-spanned if checked as non-continuous. Can it be checked as continuous, if the ply members are jointed at the Code specified locations?
I did not design the beam; the issue arises because the contractor built it with fewer supporting piers than on the drawing, but he also increased the beam depth.
