We plan to install two new boilers fired with biomass. In order to get the permit, we must install a continuous opacity monitoring system (COMS). But the thing is that our gaz pass through a cyclone and a wetscrubber, and it will be saturated in water. So the precision of the opacity measure can definitely be affected, as each water drop will be read as a PM.
We were thinking of installing a Beta attenuation technology to read PM directly at the stack and calculate opacity but this solution can be expensive.
Another avenue might be, reading opacity before the wetscrubber, and measuring the increase of contaminant in the wetscrubber solution (maybe by absorption?) and determining indirectly what is the opacity at the stack, but we're not sure if that can actually work.
Any idea?
Any idea?
