psychedomination
- Jan 21, 2016
- 123
Hi there,
I’m designing a few lintels for a small structure. These lintels are only 4’ in length. I was going to have the architect build out a small block column with filled cells to support the lintel (shown as the green square on the attached) because I had designed them lintels as simply supported.
However, he has requested to remove the column because he doesn’t agree with it in the space. The simply supported linked
I just want to make sure that I am right about the structural behaviour if the beam is continuous and the intersection is at a 90-degree angle.
L2 is an 8” wide lintel and L1 is a 12” wide lintel.
The CAD drawing is showing the beams in plan and I drew what I feel the bending moment diagram will be for the beams in an isometric view. Even though the beam intersection is at an angle I just want to confirm that the structural behaviour and analysis will be the same for a normal straight continuous beam? As in will the moment distribution be the same, e.g. I can use the hogging and sagging moment distribution ratio tables that are provided in most books? As the column is existing and has no reinforcement, I can't have any bending moments in the column.
