S
shan_p
Guest
Hello All,
the problem is like a steeped shaft enters into cylidrical hole by interference.
i tried to create contact reqgion between two surfaces (cylindrical hole and cylindrical shaft) which is not in touch with each other,having a gap. when used the option insert-contact region-creat-by face/surface i got up the below error.
"A valid conbtact region cannot be created with the highlighted entities,the two entitiesmust near one another and approximately parallel"
