Contact regions!
  • Thread starter Thread starter ksarita20
  • Start date Start date
K
ksarita20
Guest
hi ,
iam doing an analysis on a assembly. i am trying to use contact regions . but pro/e is giving an error. i am also following a text book from SDC publications. but its not working for me. can any one tell me the exact usage of contact surfaces. and how to exactly implement in pro/e
thanks in advance
Sarita
thanks.
its working. but is the exact difference between this option and contact regions.
sarita
hey ,
i am using free option instead of contact, its giving me an error as
Standard Design Study
The design study terminated abnormally.
One or more of your contact regions creates a crack at the
interface between two volumes. Please review your contact
regions.
PLease help me out.
thanks
Sarita
Sarita
In order to prevent Pro/E from fussing the two parts together in WF 2.0 and WF 1.0 there is a new connection called "FREE" under the inteface option. Assign theFREE connection to eachpair of surfaces thatare in contact but that do not needto be merged during AUTOGEM. You still need to assign a contact region in conjuntion with the free interface.
Differences:
Free interfaceflags ProE not to merge the surfaces of to bodies in contact into one body.
Contact Regionsflags proE that two or more surfaces may come into contact during the analysis.
Luis
Edited by: Luis Aguirre
hi Luis,
Once again its ur reply that helping me. thanks
wow thanks alot, i am assuming that " free" is an option which can do the same function as contact regions.
but i have another question , what is the difference between contact regions using surfaces and contact regions using parts.
Thanks in advance.
Sari
even if i use both contact regions as well as free option, i get this message
Fatal Error; Run Terminated
regions.
please , what to do, i am stuck here
Sari
Sari,
Answer to first question:
Contact region using surfaces: This option is used when you want to specify what surfaces you believe will be in contact.
Contact region using parts: Using this option gives Give MECHANICA the option to create contact regions in the surfaces it thinks may be in contact.
I prefer to useContact region using surfaces since it allows me to only specify what I think will be in contact.
Answer to the second question:
I believe the problem you are having is with the geometry. The error
regions.
has been discuss in the forum before. You may want to browse through the different pages in the analysis forum to see if you find the message in which we discuss this issue or possibly use the search tool on the top of this web page to search for the answer.
Here is the link
http://www.mcadcentral.com/proe/forum/forum_posts.asp?TID=24 822&KW=contact
Luis
hi ,
i saw this forum before and even tried to create more contact region as specified in the forum , but even then i am getting this error.
The contact regions work fine for some problems which are quite simple in geometry, so is it the problem that Pro/e is not handling well.
sari
Edited by: ksarita20
Luis explained well about creating contact . what is it you are dealing with here exactly?Contact errors in Mechanica can occur depending on what kind of assembly you have .The casewhere only2 parts come into contact is different from 10 parts do.If you have notfound a wayout to your dilemma,please give some more details about your assembly.
hi sezerserhan,
thanks for your concern, but i could figure out how they work. As you said Luis explained very well.
THanks All.
Sari
Hi all,
I am looking to use the kind of mechanica contact regions that are discussed in this thread. I remember someone mentioning a book from SDC. Can I get a title to this book? I would really like a tutorial to help me understand this feature better.
Thanks in Advance
hi,
the Text book is
Pro/Mechanica Structure
Student Edition Tutorial
Roger Toogood, Phd Eng
SDC publications
This text book is good for begining of Pro/mechanica. but the last chapter has some miscellaneous problems in which the they discussed about contact analysis.
I hope pro/e central stores has this book, check it out.
Sari
