Contact Problem ansys
miguelaf70
Aerospace
Mar 31, 2015
Hi everyone, I am having some problems while simulating contact on ANSYS mechanical, when the conact is between two plane areas it solves it without problem. However when it is between an esphere and a plane area it never converges. You can find the file attached.
Thanks in advance :)
 http://files.engineering.com/getfile.aspx?folder=f3604e5f-996b-4187-9ed5-8f1583701bda&file=este_deberia_funcionar.db
An I am also having some problems with impacts, the two blocks just ignore themselves though I have messed them like target and cONTA, Any idea about what the problem could be?
