Consumable suggestion 1
sayee1
Materials
SA
I have a 38 mm cs with 3 mm 6625 clad.
1. Is it possible to do an inconel root and 1st fill weld with ERNiCrMo3 followed by a buffer with some consumable and then weld cs on top of this buffer?
2. If yes, what should the buffer be?
I know from my limited engineering that cs cannot be deposited on top of inconel but my client says that this is possible with a buffer of some consumable type he does not remember! Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
The consumable type your client is refering to is probably called KARDO from Lincoln/Smitweld. It is used in carbon steel tubes with stainless steel cladding inside. According to the brochure it is used as a buffer on top of the stainless root , before the CS weld is made. Doubt if it works.
Ijzer,
Thanks a lot for your reply and lead. However for your future refernce I attach the reply from Technical Department of Lincoln Smitweld, who have in their program the covered electrode Kardo. One of the applications for this electrode is on stainless steel a buffer layer in 2 layers and filling up with standard CMn steel filler materials. One of the recommendations is that stress relieving is a must after welding. This method is very dangerous and it is the welder who is responsible for the dilution with the stainless root runs. It is the dilution that MUST be restricted. It must be as low as possible, otherwise we will have a martensitic weld metal.
On the other hand this kind of welding is only economic in really very heavy wall thicknesses.
So far as I know, there are only 2 or 3 companies in the world who has the experience.
The Kardo on Ni base material is NOT possible. Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
It is common (although not preferred) to weld a 'butter' pass of 316 on CS prior to the 625 overlay to reduce iron migration. I'm not sure if it would work the other way around.
