I'm in the process of designing a elevated composite concrete and metal deck floor slab for a warehouse. This slab will have rolling fork lift loads. The floor has been designed with two mats of steel, 7 1/2" total concrete thickness and 50 ksi steel beams with a single row of shear studs on the beams. The question has come up concrening construction joints in the slab. Should there be any? If they are required where should they be located? Should the shear studs be staggered instead of just a single row?
