Simple current sources can be made with just a couple of electronic parts.
For 1 to 10 mA, the LM334 can be set with a single resistor as a current source. Add a couple more components and get some temperature compensation. Go to
and search LM334 for datasheet with examples.
For 10 mA to 100 mA, a LM317 type voltage regulator can be setup with a single resistor to act as a current source. Go to
and search for application note AN-178. Many other three-terminal voltage regulators will act like a current source if connected as descirbed in this note.
There are current source diodes - a single two-lead component that will act like a current source. A little more expensive and somewhat harder to find. According to the book
"Current Sources and Voltage Regulators" by Harrison there is a CIL series of current source diodes made by Crystalonics with values from 5.1 to 51 mA. To get 100 mA, put two 51mA devices in parallel (OK, it's actually 102 mA then). The book mentions other manufacturers such as Central Semiconductor, InterFET, Linear Integrated, Solitron, Vishay, but most of their current source diode offerings have a max of around 2 to 5 mA.
Of course the book referenced has plenty of more complex designs with higher accuracy and stability, but these require more components.
