Pmatherne
- Mar 11, 2009
- 52
What do you use to determine what type of end connection you will use on a fitting.
For instance when do you use ring joint instead of a raised face or flat face
What about NPT connections?
The reason I am asking is I have seen some use 600# RTJ and then use 600# RF later.
My initial thoughts are the smaller sizes use NPT because a flanged connection would be impractical
Future PE Engineer
Pet project I am working on to help other engineers, not much yet hoping to get it grow as I learn more
Future PE Engineer
