Connection of truss for pin and roller support?
thomaschua17
4
I understand that when modelling a truss system, you should assign one end as pinned and the other as roller. This has been bothering me for quite some time now as I was told at work that just detail both the supports of the truss as an anchor bolt with base plate connection.
If I do this, won't the connection of the truss be pinned at both sides? Is there a proper way of connecting a truss to a concrete beam as a roller support?
Say the truss is a simple fink truss.
Thank you!
What supports the truss?
If the supports are flexible in the truss longitudinal direction (e.g. dimensional timber or light gage steel wall perpendicular to the truss), then a pin and roller is a good assumption regardless of the connection. While the connection may restrict movement, the wall(s) will move.
If the supports are massive and rigid, then it's possible to develop a pin-pin condition (which will affect the truss). Although it's also possible to detail a slotted bolt or sliding bearing pad connection that would ensure linear freedom.
It's all dependent on the relative stiffness. Run your truss model once with pin-roller to see how much it wants to move to inform your decision.
just call me Lo.
