harlemshake
- Nov 26, 2018
- 2
For example, moment connections framing to the column web and flange at the same joint. Let's say the column flange connection requires stiffeners, do we really need to design the stiffeners and its welds for the max loads for both the moment connections? In the past, I assumed only the maximum, not additive, since I assumed max loads won't occur at the same time.
Another example is a post sitting on top of a girder support at the same time there's a beam framing to the girder support where the beam single plate connection also acts as a post stiffener. Do we need to design the stiffener/single plate for the max loads of the post and the beam?
Please give me your thoughts.
Thanks.
Thanks.
