livecodes
- Oct 12, 2016
- 2
I have a geared motor producing about 250nm of torque. This has a typical shaft (round with the ridge/lip), which is 25mm.
I then need to connect this to a shredder shaft which is 14mm (this is a round shaft with a flat spot - see attached).
How can i connect the two together?
I saw some HRC couplings, but these seem to be for shafts that have this ridge/lip on both devices.
Any advice how i can connect the two (ideally with some sort slight misalignment protection)?
