rolo9898
Industrial
- Jan 11, 2007
- 5
What is the best method to connect a hyd motor shaft to turn another shaft about 1' away when both shafts are pointing downwards?
I was thinking of using a chain and sprockets, but was unsure if the chain could take 9,000 inch pounds of torque the hyd motor could put out. The sprocket on the other shaft would be welded. Felt a belt and pulley wouldn't hold up and installing three gears to get the same direction of rotation was a bit difficult to plan.
Thank you,
Thank you,
