Sarikahirpara
hi.....
I have this shaft fixed at one end and free at other end. I wanted to see the deflection of free end due to gravity. I am using SI system library for material (N/m2) (E= 2.1 x 10^11 , density= 7833) and applying gravity of 9.8 m/s2. but the deflection and stresses are coming very high. I suppose this is due the uncertainty of units. and also the change in position of cg doesn't make any change in result why so??
Pls if some one can suggest something
