breaking_point
I've been learning about failure theories of materials, namely the Von Mises and Tresca theories. I read that these theories are used because the accuracy of just comparing the yield stress to the maximum yield for a uni-axial test in insufficient in more complex stress states.
One thing I did notice is that when we design a beam by hand, say simply supported beam with a uniform load, we do not use these theories. Is this because we typically design and check the beam at maximum bending moment and shear for maximum normal and shear stress respectively, but these do not occur occur at the same point? i.e. at the maximum normal stress from bending there is no shear stress, and at the maximum shear stress there is no normal stress, so it is okay not to just use a basic check of normal stress against allowable yield stress and shear stress against the allowable shear stress?
I hope this makes sense, and someone can clear up my understanding!
