I have several simple bolts that have configurations for the length. Often (but not all the time) when I insert for instance a M8 X 25 configuration it may come in as a M8 X 35. When I check the properties the use named configuration is checked. I simply have to reselect the config I need and it will correct itself. Is there some global setting for an assy that over rides my selection?
TAP
TAP
