cmarinelli
Hi all,
I was wondering if anyone had a solution or workaround for the following:
I have a Extrude-Cut Feature that has one dimension that is different for two configurations. My question is: can the tolerance be different for the two configurations? Is there any other work-around for this?
I suppose I can copy the sketch and create another Extrude-Cut feature for the alternate configuration. If I copy the sketch, can I edit it without changing the original sketch? Anyone know an easier way?
Thanks in advance,
Chris Marinelli
Thanks in advance,
Chris Marinelli
