Config files update utility
  • Thread starter Thread starter DanD
  • Start date Start date
D
DanD
Guest
Hello all,
I need a script to automatically update the config file(s) -from network to C drive- every time the user starts Pro/E. Any suggestions?
Thanks,
Dan
I modify our Pro/Intralink batch file with something like copy x:\ptc\proe2001\config.pro c:\proe-loadpoint\text as well as my menu def.pro and color.map files so that each time they fire up the Intralink app. manager they get the latest copy of these files. Hope this helps.
I use a batch file that sits in everyones start up directory, so it runs everytime they log on. It trys to load into very possible place ProE may be installed, if the place doesn't exisit it just skips it:
echo off
echo ** Starting Config.pro Copy Utility v1.5.2 - updated 10-May-02 **
echo
echo c drives
COPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO c:\progra~1\proe2000i\textCOPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO c:\progra~1\proe2000i2\textCOPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO c:\progra~1\proe2001\textecho d drives
COPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO d:\progra~1\proe2000i\textCOPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO d:\progra~1\proe2000i2\textCOPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO d:\progra~1\proe2001\textCOPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO d:\proe2000i\textecho e drives
COPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO e:\progra~1\proe2000i\textCOPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO e:\progra~1\proe2000i2\textCOPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO e:\progra~1\proe2001\textecho
echo
COPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO c:echo
echo ** Finished **
We use these commands (with PTC_HOME & PROELOC defined appropriately):
xcopy %PTC_HOME%\config\config.win* %PROELOC%\text\ /d
xcopy %PTC_HOME%\config\config.pro %PROELOC%\text\ /d
The /d means it will only copy if the network version is newer.
