I use a batch file that sits in everyones start up directory, so it runs everytime they log on. It trys to load into very possible place ProE may be installed, if the place doesn't exisit it just skips it:
echo off
echo ** Starting Config.pro Copy Utility v1.5.2 - updated 10-May-02 **
echo
echo c drives
COPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO c:\progra~1\proe2000i\textCOPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO c:\progra~1\proe2000i2\textCOPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO c:\progra~1\proe2001\textecho d drives
COPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO d:\progra~1\proe2000i\textCOPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO d:\progra~1\proe2000i2\textCOPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO d:\progra~1\proe2001\textCOPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO d:\proe2000i\textecho e drives
COPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO e:\progra~1\proe2000i\textCOPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO e:\progra~1\proe2000i2\textCOPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO e:\progra~1\proe2001\textecho
echo
COPY \\SANDY\server\PM_SETUP_FILES\CONFIG_PRONT\CONFIG.PRO c:echo
echo ** Finished **
