Cone & Taper 1
SupaFlyer
5
Is there anykind feature how i make conical sheet? I have one my own projects and i like to make cap on the smoke pipe in my forest cabin, i cant find any working feature to flat sheet when i draw cone and i have cutted line to flat it.
I have an example of what you want but I do not know how to attache to this post? :cool: If you can tell me how to do that or give an email address I will forward.
If you are using the sheet metal template, there should be a command for 'flat pattern.' That is the only way to 'unroll' a cylindrical shape.
Unfortunately, I don't know if there is a way to create a cone in sheet metal and get a flat pattern. I know it'll do any other shape. I've created some pretty trick brackets and they were flat patterned perfectly. So I know the feature works, but I just don't know if it works for cones.
Maybe someone on here can elighten both of us.
Inventor unfolding can do with significant improvement. If its just the flat pattern of a simple cone you want then it's so basic I'd say it was easier just to draw it.
