I need to select conductors for a small starter motor. 12 vdc, 125 amps, intermittent duty - same duty cycle as a car starter. Each conductor about 8 feet long. Flexibility and resistance to sunlight desirable. I know the conductors don't need to be rated for continuous duty, but I don't know how they should be sized for intermittent duty. I imagine two separate conductors or two side-by-side conductors, like in a jumper cable, would be better than a cable with an overall jacket, due to heat dissipation considerations. Any suggestions?
