twr
Chemical
- Jun 30, 2005
- 21
We have a shell and tube condenser off a flash chamber - product temperature into the flash chamber is 300ºF, we want to drop the temperature to 185ºF but no lower. If we go lower our solids increase and puts the product out of spec.
The condenser has been fouled. We ran an acid wash through the system and it is running better.
As part of this project I contacted the OEM. They provided engineering data that indicates a vapor temperature drop from 300ºF in to 100ºF out.
My first question is - if we run cooling water through the condenser to drop the vapor temperature to 100º F, will that also drop the product temperature out? Right now the vacuum on the condeser varies between the saturation pressure of the product out the flash chamber and the saturation pressure of the vapor into the condenser.
My second question - the engineered LMTD is calculated out to be 65. Our condenser had been running at LMTD of 125. After the cleaning, with a limited increase in shell side flow, the LMTD came down to 117. Should I try to get the LMTD back down to 65?
This site has helped me immensely get as far as I have. Now I'm looking to change the control around a bit further, possible optimization on the condenser cooling water loop to limit the flow of raw water in.
