Hi
I am designing return line which collects condensate from couple of steam traps. Steam pressure upstream control valves is 12 barg, control valves reduces steam pressure to 6 barg.
The problem is that I need to lift my common line over a door. Usually I lift condensate from a single steam trap but I am not sure if I can do this in described situation.
What do you think?
What do you think?
