We are designing a 12 story building in etabs using a system of shear walls and one and two way concrete slabs. In most cases the walls are 50ft long until we get to the parking garage where a 30ft hole is punched through. The walls on each side of the opening are 10ft long and 12 inches thick. Ignoring lateral effects we expected the loads in the wall to be evenly distributed to the foundations below these lower walls. However etabs is transferring all the load to the outside edge of the support walls and not distributing it evenly as we would have assumed. why is this.
