JStructsteel
Got a barn that the owner wants a concrete wall up 5 feet around the perimeter. Plan was to pour around the wood columns. Whats a good waterproofing/barrier to use?
End result will be siding above concrete, so no direct impingement of water at the top. Should be relatively dry inside.
I had thought about a drainage board around the column, that would help isolate the column too.
Thoughts?
Thoughts?
