Concrete Wall Twisting Moment
ChiEngr
77
I am working on a complicated retaining wall structure for a Bioretention area. I have modeled the structure using plates in RISA-3D. Given the lengths of the walls, I have chosen to implement a strut between walls to relieve the flexural demands on the walls resisting the lateral earth pressures. When designing the walls for vertical and horizontal reinforcement, I am considering the plate moments Mx and My, however I am confused when it comes to Mxy.
My understanding is that the Mxy moments are out-of-plane twisting moments on the wall. Is this synonymous with torsion on the wall? I have never designed a wall for torsion and am quite confused as to how these twisting moments are resisted. Has anyone ever experienced this or have any guidance? Below is a screenshot of my model. Thank you in advance!
Twisting moments are generally combined with orthogonal moments to get your design moment. One of the most popular methods to do so is the Wood-Armer method. (You can probably do a search on here and find some threads discussing it.) Personally, I just add the absolute value of the twisting moment to the [absolute value of the] Mx or My moment and run with which ever one is higher. (Which is similar to the Wood-Armer method.)
