Oh, great, 50F is workable.
Five days to service is definitely achievable. Honestly, a 28 day 40MPa mix would likely get you to 20MPa around then without much help. Might as well use at least some admixtures or a fast early strength mix though.
How are your concrete suppliers? Here, I would call up a supplier (or work through the contractor) and see what mixes they have that they would be comfortable standing behind. Something with some test history behind it in production.
Five days isn't even that fast. You can get crazy mixes now from some of the major suppliers that'll hit high early strength in four or six hours. They dump heat like crazy, need to be carefully cured and seem terrifying to work with because you have no time, but you can do it.
From a durability standpoint, if you could wet cure for that full five days it'd probably be beneficial. Are these inflated tire forklifts or hard wheel?
The big thing on jobs where you're going into service or advancing work before 28 day strength is to pick the strength you feel comfortable with ahead of time. Set a limiting strength and field cure some cylinders in the same conditions as your pour. Then test them before you release the slab for operation. Stay firm on the number you decided ahead of time. It doesn't necessarily need to be the 30MPa full strength you're mentioning. If it seems to the contractor or owner like you're just going by feel, you're going to feel pressured on that hold point. If it's a hard number, then it is what it is.
