I’m not a civil engineer, but in the metal finishing business, chemically resistant bermed areas are required. For concrete pours, we use a high strength (6000 psi), stiff mix for a low shrinkage, non porous, high density concrete. After curing, a penetrating concrete sealer is applied before adding a liner.
For your case, the lifetime of the tank will be limited by chlorine-initiated attack on the rebar. This attack can be minimized by using high density (low porosity) concrete, a sealer, epoxy-coated or stainless steel rebar, and galvanic protection. I assume that you will be taking some measures, and maybe rethornton’s references cover the subject as well. I suggest that you review previous threads (thread507-14533,thread592-40952, thread338-43027) on corrosion of rebar. Perhaps, the first 2 or 3 preventative measures I listed may be cost-effective when maintenance, reliability and lifetime are considered.
Also, a quick search for sealers found the following:
“SUPER~SEAL Penetrating Concrete Sealer is recommended for:
Any exterior exposure subject to freeze / thaw attack.
Marine structures such as docks and piers subject to attack by water and chloride intrusion.
Bridge decks and parking decks that are under constant attack by oil, water and de-icing salts.”
