We are currently in the construction phase of a wastewater treatment system. We have a tank being installed that has 7 reinforced concrete sections with vertical joints. At two of the joints the contractor is unable to push it home, leaving roughly a 2 inch gap all the way around. The water depth in this tank will be approximately 7 feet. The manufacturer is acknowledging it is most likely due to cold temperatures, but claiming that because the gasket is fully seated it is a non-issue. They are proposing to finish by filling the gap with a hydraulic cement. Is there anything else I should consider and would this be common practice? Thanks.
