dm3415
- Sep 27, 2007
- 50
Does any have any insight or experience with concrete actually decreasing in strength from 28 to 56-days? We are having three different entities test cylinders from a precast plant independently and all are coming up with similar results. 28-day strength is around 10-12,000 psi compression and then the 56-day breaks are around 7-9,000 psi. All are ACI approved testing facilities using ACI methods, so there doesn't appear to be any results due to testing error. This is a high-strength high-pozzolan mix and we are at a loss.
