I'm checking an existing concrete slab on grade for new equipment loads. The existing 8" slab was poured on top of an older 6" slab-on-grade; only friction connects the two.
I will assume that the two slabs do not act together. How does the lower slab (that is directly on grade) effect the bending in the upper slab? Is there a way I can adjust the modulus of subgrade reaction to account for this?
The load from the equipment is about 30 kips per leg. The 4 legs are spaced about 7.25 ft apart in a square.
Thanks for the help.
